MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Online Checkout
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Click for Detroit Diesel manuals!
Results 1 to 3 of 3
    Post 671 Ti audible engine alarms
    I am in contract to purchase a 1983 44' Viking MY w DD 671 TI's. 2700 hours. Surveyor says in pretty decent shape. No overheating, no oil leaks, oil pressure a little low at idle speeds, but still in acceptable range.. No black smoke etc. Runs good. One issue we couldn't figure out. In shifting the engines between forward and reverse at different RPM's we got an audible engine alarm consistantly. Thought that it may be a low oil pressure alarm, but it happened at higher rpms and when the oil pressure was up. Only when shifting. Anyone have any ideas why? I am going to have a marine diesel tech look at the engines...but I'm just curious if anyone else has encountered this issue. Doesn't seem to have any effect on performance as the engines ran well at full throttle, idle and everywhere in between. ???
    Aug 2009
    Hobart, Tasmania, Australia
    114
    Default Re: 671 Ti audible engine alarms
    G'day Bill,
    Could be Gearbox low oil pressure alarm circuit if fitted. Happens when clutch pack dumps oil between changes,clogged filter will all so cause problem.
    Cheers, Shakey.
    Jul 2011
    Cranston RI
    9
    My 44 Ocean does the same thing when the engines are fully warmed up. When I shift, the rpm drops just enough to reduce oil pressure and trigger the bells. My port engine runs at 40 lbs but at idle 'hot' it drops to 15 lbs. Starboard engine runs at 60 lbs and 25 lbs .
    The alarms will go off on both engines when shifting into reverse for a fraction of a second. This does not happen all the time. I don't like it ,but I have had the boat for 6 years and this condition has not changed. My friend has the same model and engines and his does the same thing.
  1. audible alarm
    By wright in forum Volvo Penta Gas Engine Forum
    Last Post: 11-25-2011, 04:19 PM
  2. Audible Alarm
    By carl h in forum Yamaha Outboard Forum
    Last Post: 07-29-2011, 08:05 PM
  3. Erratic audible alarm
    By munroe in forum Mercruiser Sterndrive Archive
    Last Post: 06-15-2009, 10:54 AM
  4. Continuous audible alarm
    By brow931 in forum Mercruiser Sterndrive Archive
    Last Post: 05-29-2009, 04:02 PM
  5. Merc 350 MPI Engine Alarms
    By DC in forum Mercruiser Sterndrive Archive
    Last Post: 06-13-2007, 11:16 PM
