Results 1 to 4 of 4
  1. #1
    Default 3208 Exhaust manifold coolant leak
    I just replaced an exhaust manifold on my 375 hp 3208 with an aftermarket aluminum manifold. There is coolant leaking around all of the mounting bolts. My mechanic doesn't think there should even be coolant in the bolt passages. Is this true or do the bolts maybe go into coolant passages in the head? Any help would be appreciated.
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,866
    Default Re: 3208 Exhaust manifold coolant leak
    If there is coolant leaking out of Attaching bolts for the manifold then I would say they go into the water jacket. Loosen all the bolts and pull one at a time and apply sealer and reinstall then and then re-torque.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    I have since learned that there is a defect in the manifold allowing cooling water into the bolt jackets. Do you think it is safe to seal the bolts as an easy fix?
  4. #4
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,866
    Replace the manifolds.
    Chris
    Jersey Shore.
Similar Threads
  1. aq125a Exhaust manifold leak, gasket question
    By discobayken in forum Volvo Penta Gas Engine Forum
    Last Post: 11-30-2011, 04:58 PM
  2. 318 fwc exhaust manifold coolant fitting
    By eero_karppa in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 11-24-2009, 07:28 AM
  3. Exhaust manifold leak
    By bushwood in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 03-18-2009, 07:33 AM
  4. 30 lt mercruiser exhaust manifold water leak
    By brentjmorgan in forum Mercruiser Sterndrive Archive
    Last Post: 03-07-2009, 08:07 PM
  5. MCM 170 leak between coolant tank and manifold
    By rmm in forum Mercruiser Sterndrive Archive
    Last Post: 07-28-2008, 08:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
