MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Online Checkout
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Click for Johnson Evinrude Diagrams, Parts and Manuals!
Results 1 to 6 of 6
  1. #1
    Join Date
    Mar 2012
    Location
    Royal Palm Beach, FL
    Posts
    5
    Default How do I remove VRO from 225 High Output Johnson
    Looking to remove VRO, too many family and friends have lost engines due to failure!
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    2,953
    Default Re: How do I remove VRO from 225 High Output Johnson
    Unless you can mount a different fuel pump you cannot just remove the VRO, it is also the engine fuel pump. You will need to post the actual complete engine model number so we can direct you to the correct set up.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Let the insanity begin.
  3. #3
    Join Date
    Mar 2012
    Location
    Posts
    5
    Chris thanks for your quick response,
    The Model # is J225HPLEEN 1999yr.
    Quote Originally Posted by Docksidemarineservices View Post
  4. #4
    Join Date
    Mar 2012
    Location
    Posts
    5
    Maybe I mislead you, how do I disable the VRO and what wires do I need to also disconnect so the warning alarm doesnot sound? From some of the forums I understand I need to unlug the Black and Tan wires coming from the VRO side but had read that there is also a 4 wire plug that has to be disconnected and taped or covered.... is tape true or it just the black and tan from the VRO?
  5. #5
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    2,953
    Just unplug the vro cut the oil line and plug it up with a bolt and a clamp. Good to go. I would remove the pulse line and make sure there is no fuel present. If there is you need a new pump.
    Chris
    Jersey Shore.
  6. #6
    Join Date
    Mar 2012
    Location
    Posts
    5
    Chris thanks again, the motor doesn't have many hours on it at all and runs like new ever since I had the Carbs rebuilt from sitting, but they recommended I remove the VRO as most of their work comes from VRO failures plus those I know that have had problems!
Similar Threads
  1. Kolher 5kw voltage output high
    By WALTER IHNE in forum Boat Electrical Systems
    Last Post: 07-31-2011, 07:27 AM
  2. 1990 155HP commercial engine High voltage output
    By jezorek in forum Johnson Evinrude Outboard Archive
    Last Post: 04-20-2009, 07:42 PM
  3. High RPM no output to Prop
    By marchnsk in forum Mercruiser Sterndrive Archive
    Last Post: 05-25-2008, 02:06 PM
  4. New engine installation High output eng Alpha One Gen 2 breakage
    By beech2000 in forum Mercruiser Sterndrive Archive
    Last Post: 04-16-2007, 06:24 PM
  5. High voltage output on 1993 175 HP Merc Outboard bad reg
    By danno in forum Outboard motors archive 2000-2004
    Last Post: 05-06-2004, 11:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
