Results 1 to 2 of 2
  1. #1
    Default how to check oil in power trim clyinders on 150 pro v engine
    need to find out how to check oil in power trim clyinders on a 1990 150 prov yamaha outboard engine
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    3,685
    Default Re: how to check oil in power trim clyinders on 150 pro v engine
    Tilt the engine all the way up, remove the fill plug and fill it til it just starts to spill over. You will see what to do when the engine is all the way up. You cannot do this while the boat is in the water.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Let the insanity begin.
Similar Threads
  1. 2002 Honda BF 130, how to check power trim fluid level?
    By Cohiba in forum Honda Outboard Forum
    Last Post: 11-27-2011, 06:58 PM
  2. Volvo Penta Engine Shut Down- 5.0 OSI- Power Trim Fuse keeps blowing
    By jamesr in forum Volvo Penta Gas Engine Forum
    Last Post: 07-25-2011, 12:53 PM
  3. 2004 230 5L MPI Engine shows Check Engine Alarm
    By robflyn in forum Mercruiser Sterndrive Forum
    Last Post: 09-14-2010, 04:47 PM
  4. Volvo Penta 50gxic engine power trim piston
    By Maureen in forum Volvo Penta Gas Archive
    Last Post: 05-30-2008, 06:22 PM
  5. Check engin light keept going off under power
    By wesley in forum Johnson Evinrude Outboard Archive
    Last Post: 08-07-2007, 08:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
