marvin1952
Thisis the same engine that I just replaced the rectifier. That fixed the no TACH and is now charging, It starts when you choke and will idle for a sort while then goes dead, I have to choke it when it over and over when it starts to go dead and throttle up for a minute or so. Then you can engage the gears and accelerate. The engine will run fine afterward and will idle the boat in gear, but if you kill the engine and set for a for a short time you have to go thru the hard start and coax it to pick up the fuel so I can take off again. I have looked for fuel line leaks and do not fine any. It acts like it is loosing prime once the engine idles for a time. Could this be a fuel pump week diagram or is there a check valve inline on the fuel line. The fuel filter stays full of fuel and the bulb stays hard. I am at a lost. Other wise the engine runs great???????
marvin thomas
[email protected]
cell 901-485-3712
marvin thomas
[email protected]
cell 901-485-3712
