Results 1 to 2 of 2
  1. #1
    Default gamefisher 15 hp 225 581505 model pee hole not working
    i could use some tips on how to clear the pee hole...have tried weedeater string, air pressure etc. with no success. how do i know the water pump is working? it will idle fine and doesnt appear to get too hot, but im reluctant to use it without knowing for sure the water pump is functioning properly.
  2. #2
    Default Re: gamefisher 15 hp 225 581505 model pee hole not working
    Water should be coming out the exhaust port on the back of the engine. some gamefishers (Force) don't have a "pee hole". My 10 HP does not. Mine is a 1988 Gamefisher Model # 225.581990 Serial # 1398.
Similar Threads
  1. Gamefisher 75 HP Model #217585932 Serial #08192376
    By ko4nrbs in forum Gamefisher Outboards
    Last Post: 11-10-2009, 08:24 PM
  2. How do i check if the Water pump is working properly Johnson 1975 50hp model 50ESL75 B
    By Katrina Turner in forum Johnson Evinrude Outboard Archive
    Last Post: 01-22-2008, 05:27 AM
  3. Gamefisher 175
    By ithrashmycj5 in forum Archive 2003-2009
    Last Post: 06-05-2007, 01:24 PM
  4. Replies: 0
    Last Post: 04-24-2004, 09:12 PM
  5. Gamefisher model identification
    By michael in forum Outboard motors archive 2000-2004
    Last Post: 02-14-2003, 11:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
