MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 8 of 8
  1. #1
    Default no water from tell tale
    Just finished rebuild on the powerhead on a 95 40hp Mercury. Started it and it runs like a sewing maching, smooth as silk. One issue, no water from the tell tail. I put in a new impeller this past summer. Any suggestions?
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,822
    Default Re: no water from tell tale
    Are you running it on a set of muffs or in a garbage can?
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,471
    Tell Tales get plugged. Are you SURE it's not pumping water? If you can keep your hand on the exhaust side of the power head it's okay.
    Jeff
    PS: Good time to break out my favorite diagnostic tool" an infrared temp gun.
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Disconnect the telltale hose from the powerhead to see if water shoots out. If it does, like Jeff said, the hose is clogged.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  5. #5
    Join Date
    Jun 2008
    Location
    Malden, MA,
    Posts
    341
    two other things you can try, drop the lower unit, and put a hose right on the tube the water pump attaches to, it should gut up through the pee hole, and with the lower unit off, attach the muffs and rotate the shaft by hand or with some padded vice grips. You should see the water come up the tube, and you can also see if any the pump housing has leaks or is not tight enough.
  6. #6
    UPDATE: Pulled lower unit, pump is fryed. Take note kids; don`t "test" fire your motor with no water. Not even for a second. The motor turned over for about 10 seconds and now I need a new pump assembly. On another note, anybody know if water goes up to the powerhead and only to the powerhead. Does is come out of the bottom at all?
  7. #7
    Join Date
    Sep 2003
    Location
    Posts
    15,471
    Only if there's a leak!
    Jeff
    PS: The newer motors--with their plastic pump housings--have NO tolerance for dry running. TH\he older motors (metal housings) would have survived that.
  8. #8
    Thanks Jeff. New pump on the way and lesson learned....
Similar Threads
  1. Warm Water out of the Tell Tale
    By captb in forum Honda Outboard Forum
    Last Post: 05-25-2010, 12:28 AM
  2. Tell Tale water stream
    By mobiletec in forum Johnson Evinrude Outboard Archive
    Last Post: 09-04-2008, 06:38 PM
  3. How hot is tell tale water
    By coffeeguy in forum Mercury Mariner Outboard Archive
    Last Post: 06-20-2008, 03:35 PM
  4. Water from tell tale hose
    By tgmcree in forum Mercury Mariner Outboard Archive
    Last Post: 04-03-2007, 01:41 PM
  5. No water from the tell tale new impeller
    By Ken Sikora in forum Johnson Evinrude Outboard Archive
    Last Post: 07-27-2006, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
