MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 14 of 14
  1. #1
    Default motor wont stay running
    hi. i recently purchased my first boat. its a 14ft aluminum with a 1975 20hp merc 200. the motor ran awesome here at the house. a couple of weeks ago i took it to the lake to try it out and i started having problems. first off, it had trouble starting. then when i got it started, it wouldnt stay running. it only runs for a few seconds after i prime it. so obviously its a fuel issue. i bought a new fuel pump diaphragm for it and that didnt fix it. im thinking something may be plugged in the carburetor maybe? i have a clymers manual and im thinking i may just disassemble it and clean every little orrifice. any other ideas? thank you
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,505
    Default Re: motor wont stay running
    Clean carburetor , likely dirt in it.
  3. #3
    well, i disassembled the carb and cleaned it. it seems like that may have done the trick. i also cleaned the passage in the engine that lets the crankcase vacuum get to the fuel pump. it runs like a champ now. only problem now is sometimes it doesnt want to spit water from the pee hole. i plan on replacing the impeller anyway since i dont know when it was done last. i think i got a pretty good deal on this boat for $600 with trailer, motor, current registration, fish finder, and all the extras (anchor, oars, etc)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    i think i got a pretty good deal...
    you bet...enjoy but replace the impeller and thermostat if equipped.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,505
    No need to look for a thermostat , it did not come with one.
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,389
    Whoa! Don't got off on a tandem until you read this:
    That motor (and Merc 110s--9.8hp) are notorious for plugged Tell Tales--the dopey angled fitting in the lower cowling plugs up very easily. My usual solution is to blow compressed air back wards as the motor runs (hard to do 'out there'). A wire can be used to poke te hole out, but if you want to eliminate it completely do this:
    Remove the plastic fitting and throw it away, then lengthen the hose and poke it out the bottom of the cowling (with a tie wrap to keep it out there). Problem solved, permanently.
    Jeff
  7. #7
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,505
    Old impellers are subject to " sudden failure " and if it does you will destroy a fine motor.----------Replace it if you do not know how long it has been in there !!
  8. #8
    i replaced the impeller. it has waaay better water flow now
  9. #9
    Join Date
    Sep 2003
    Location
    Posts
    15,389
    Good deal. But don't panic if the Tell Tale suddenly stops working; the Tell Tale on those motors regularly plug up and need poking out.
    Jeff
  10. #10
    Join Date
    Sep 2003
    Location
    Posts
    15,389
    ..."Allways top the gear oil off before every"
    Why? You think the thing will lock up if there's a tablespoon of oil missing! They can run 50% empty without a hint of trouble.
    Jeff
  11. #11
    Join Date
    Sep 2003
    Location
    Posts
    15,389
    ..."Hummm what service manual says to run it until it gets half empty of gear oil,.."
    Never said that, but the LU will operate just fine a 50 % oil capacity.
    .."if you keep it topped of the upper bearing and seal will last alot longer."
    I doubt it. At even 500 rpms the oil is flying all over the place in there.
    Jeff
  12. #12
    Join Date
    Sep 2003
    Location
    Posts
    15,389
    There's a misconception on oil levels caused by a lack of a dip stick to check oil levels. LAcking said device, the only safe way to determine the level is to fill it to the top. That way it's got plenty of oil, agreed?
    In the industrial world of gearboxes, there is a sight gage to determine proper oil levels, which is close to 50 %. This level reduces the tendency of the oil to aerate, which lowers its viscosity (and lubricating ability). Note the car engines are never run full of oil for the same reason. Also note the warning usually placed on the dip stick not to "overfill".
    Jeff
  13. #13
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,505
    Always make sure outboard gearbox is full to the top, running them any other way risks disaster.---------The upper thrust bearing will fail , with motor coming to a " dynamic halt "
  14. #14
    Join Date
    Sep 2003
    Location
    Posts
    15,389
    ..."The upper thrust bearing will fail "
    Not really.
    Jeff
Similar Threads
  1. Motor wont stay running
    By inkmanaj in forum Suzuki Outboard Archive
    Last Post: 05-28-2008, 01:22 AM
  2. WONT STAY RUNNING
    By stevewat in forum Mercruiser Sterndrive Archive
    Last Post: 10-20-2007, 04:31 PM
  3. Engine wont stay running
    By mcazille in forum Mercruiser Sterndrive Archive
    Last Post: 09-11-2007, 04:54 PM
  4. Wont stay running
    By mike wendel in forum Johnson Evinrude Outboard Archive
    Last Post: 05-27-2006, 06:11 PM
  5. VolloPenta 43 wont stay running
    By robncar in forum Volvo Penta Gas Archive
    Last Post: 05-23-2006, 09:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
