Results 1 to 2 of 2
  1. #1
    Default Refilling coolant system
    I have a Universal M35b and I have replaced the thermostat, impeller, heat exchanger, and all of the hoses because of an overheating issue i am trying to solve.
    My question is: What is the proper way to refill the coolant system.
    Thank you for your time,
    chris
  2. #2
    Default Re: Refilling coolant system
    I open the bleed valve on top of the thermostat housing , then fill with coolant till you get fluid coming out of the bleeder. Start and run engine at high idle , shut down and refill , repeat as many times as necessary. Have you checked the gasket at the exhaust riser ?
Similar Threads
  1. Coolant system pressure test 6.0 L
    By jimw in forum Crusader Marine Engine Forum
    Last Post: 04-11-2011, 01:56 PM
  2. Purging the Coolant System After Riser Replacement
    By Conundrum in forum Crusader Marine Engine Forum
    Last Post: 06-12-2010, 07:07 PM
  3. Flush coolant system
    By dsiegfried in forum Volvo Penta Diesel
    Last Post: 11-25-2009, 07:39 PM
  4. Refilling leg oil on 1989 90hp VRO
    By chris szymanski in forum Johnson Evinrude Outboard Archive
    Last Post: 06-25-2007, 08:34 AM
  5. Refilling an b63 Evinrude Starflite 100S Selectic gearbox
    By cannondale70 in forum Johnson Evinrude Outboard Forum
    Last Post: 01-07-2003, 11:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
