Click for Perkins manuals!
Results 1 to 4 of 4
  1. #1
    Question perkins 4107 oil pump issue
    Hi does anyone know why the oil pump may have an issue, there seems to no pressure after a cold start, is there a problem with the plunger sticking????? Is there a way to free it without taking it apart
  2. #2
    Default Re: perkins 4107 oil pump issue
    Hi, it's unlikely that the relief valve is stuck or the rotary pump is bad. Most likely you have electric gages and senders which are prone to be the culprit from vibration and corrosion. I suggest you hook up a mechanical oil gage at the engine and check the pressure. Has the oil filter been changed and did the problem start then ??
    Charlie w.
  3. #3
    New gauge fitted no oil to the top end, stripped oil pump down and have slight scoring on the plunger, is the pump knackered now or can u buy spate parts?
  4. #4
    Hi, was relief valve stuck ?? Is there shiny metal particles in the oil or on the bottom of the sump ? I would check the lube oil pickup tube for cracks and the oil cooler for blockage. Fine scratches are normal on the relief valve. Clean them up with 220 grit followed by 400. Clean up valve bore as well and clean throughly !! Replace the spring or for piece of mind replace the pump. Don't forget to fill the pump with oil and turn the drive gear slowly to lube the pump before installing.
Similar Threads
  1. perkins 4107
    By mchael in forum Perkins
    Last Post: 08-07-2010, 07:30 AM
  2. Injector pump problems 4107 perkins
    By ningning in forum Perkins
    Last Post: 01-03-2010, 10:27 AM
  3. Perkins 4107 spares
    By bigman1 in forum Perkins
    Last Post: 09-10-2009, 06:04 AM
  4. PERKINS 4107 SN 7115420
    By a_dossett in forum Perkins
    Last Post: 07-18-2007, 04:36 PM
  5. Perkins 4107
    By iand in forum Perkins
    Last Post: 04-13-2006, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
