Results 1 to 4 of 4
  1. #1
    Default yamaha vmax 200 HPDI compression
    I have a Yamaha Vmax 200 HPDI outboard. Wondering what the compression should be on it? I am getting
    between 90 and 95 psi per cylinder. This seems low to me but the motor seems to run ok other then a slight miss.
  2. #2
    Join Date
    Jan 2012
    Location
    Giessendam, Zuid-Holland, Netherlands, Netherlands
    Posts
    102
    Default Re: yamaha vmax 200 HPDI compression
    If all cylinders are equal, it is fine.
    Slight miss is also acceptable, these engines run like normal 2-stroke engines (not as a E-tec or a 4-stroke).
    You could install new spark plugs and decarbonize the engine with Engine Tuner (Evinrude)/Power Tuner (Mercury), that could help a lot if carbon is the issue.
  3. #3
    Join Date
    May 2011
    Location
    Alaska
    Posts
    296
    120 is better. If you aren't running Yamaha RING FREE I would start. Possibly even do a shock treatment. Those motors run on 4 cylinders in neutral so that may be your miss but otherwise throughout the rpm range you should not be missing unless there is a problem. You may have some intermittent spark plug bridging when you start with the ring free but that should clear up as the motor cleans up.
  4. #4
    Super low compression unit. I have a pair on my 28 Bertram. The only thing that is high pressure on a HPDI is the fuel rail pressure. Thanks Martin Yes PRBMAN is correct with his ring free. I would also be running Seafoam, your unit will loveit and you cannot overdose it.
Similar Threads
  1. 225 vmax hpdi power head removal
    By dtbm in forum Yamaha Outboard Forum
    Last Post: 09-12-2011, 07:32 AM
  2. 2002 175 hp vmax hpdi
    By maxwelllbvsdorg in forum Yamaha Outboard Forum
    Last Post: 01-03-2010, 09:40 PM
  3. Yamaha F series or VMax Series II HPDI
    By toons in forum Yamaha Outboard Forum
    Last Post: 09-27-2009, 10:32 AM
  4. 2004 225 Yamaha HPDI Compression Readings
    By bcrank in forum Yamaha Outboard Archive
    Last Post: 02-09-2008, 09:43 PM
  5. Yamaha hpdi 2001 200hp compression question
    By shawn l jacob in forum Yamaha Outboard Archive
    Last Post: 12-31-1969, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
