Hey guys finally got a new boat after getting rid of my 1954 matthews. I picked up a 1973 32' Luhrs fly-bridge. Its got twin FWC 318's with what I believe are paragon v-drive transmissions. I am the second owner and got it from the family that knows nothing about it as the original owner died. I have a few questions and would like to know if you guys and gals could help me out.
1. After firing up both engines, I checked for discharge ovbd and all was good. within about 5 minutes the STBD engine was at almost 170* i revved it a few times and it continued to go up so I secured it. Coolant was full before and after. I am going to double check the temps with my laser temp gun, and if it is in fact running hot I will pull the thermostat to see if that is the culprit. What do you think of this? did i miss anything?
2. Both motors sat for a while and the carbs are at a minimum in need of a good cleaning and possibly accelerator pumps as they are not working. It has the original cater units and I will utilize these until I have enough money burning a hole in my pocket to buy Edelbrocks. I was wondering if there is an interchange for carburetor kits available from say NAPA or kragen?
3. What is the best way to identify the make and model of the transmission and v drives so I can buy a service manual?
This should do for at least a week. After I get all these figured out Im sure I will have another list. I appreciate any help I get from the members here. The First big project I have lined up i to replace the exhaust manifolds, risers, and elbows $$$$.
Thanks, will
Thanks, will
