Kenneth Winningham
I have a 1993 150 intruder. When i take it to the lake and start it, it may start and run for 5 seconds and die. This may happen 6 to 10 times and then it may start or it may flood and then it takes 30 minutes or so and then it may start after the 2nd or 3rd try and run just fine. When it dies it is just like you turn the switch off. I have had the powerpack, ignition, plugs and stator checked but everything check o.k. At that time. It is an intermittent problem so maybe this stuff checked good at that time, because when i had it check out it started and ran just fine. The problem has been going on for 2 years and still haven't found the problem. Does anyone have any suggestions?
