MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Default mercury trim tab anode positioning
    i have a merc 90 .1984. no anode on it....boat glasstron gt 150.boat turns way to the right.where do i position the trim anode.right or left.
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Re: mercury trim tab anode positioning
    Think of it as a rudder...turn the rudder HANDLE to starboard (right) and the rudder moves to port (left)...boat turns to port.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    thanks ,so all i gotta do it set it a little to the right and it should go a little more left....i got it with out an anode it it pulled right a lot...thanks again..andre.
  4. #4
    i might be wrong but after thinking about it ,i gotta position it left,facing rear of boat to straighten out natural turn of propeller.....am i right.
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    now you got it.
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,471
    Note that the trim tab only works correctly in a narrow speed range. Above that speed the steering will still pull one way, and below that the other way. The trick is to dail it in for your prefrred cruising speed, which is best done by experimentation.
    Jeff
  7. #7
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,479
    From the rear.If it pulls right then turn it right.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  8. #8
    ok now i got to get a new bolt to go to trim tab.how long what thread,metric ?.i tried and went thru tons of em .it stripped out.so i start over with a new trim tab and bolt .what boltnd thread size a is the problem
  9. #9
    Join Date
    Sep 2003
    Location
    Posts
    15,471
    Probably 3/8 UNC.
    Jeff
Similar Threads
  1. 1982 mercury 85 hp trim compatable with 1986 mercury 75 hp trim
    By tgarner039 in forum Mercury Mariner Outboard Forum
    Last Post: 11-17-2011, 03:15 PM
  2. B75 anode
    By edevon in forum Honda Outboard Forum
    Last Post: 01-19-2010, 01:19 PM
  3. Do you know what a anode is and what is it for
    By huey42 in forum Mercury Mariner Outboard Archive
    Last Post: 09-19-2009, 12:13 PM
  4. Removing Trim Tab Anode on Alpha One Gen 1
    By jklock in forum Mercruiser Sterndrive Archive
    Last Post: 05-12-2009, 10:00 PM
  5. 1982 Mariner 60 hp 2 cyl Ser 675 Cam Positioning On Shift Shaft
    By vette_61 in forum Mercury Mariner Outboard Archive
    Last Post: 02-23-2007, 02:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
