hi I have a older 1970 60 hp. The stock coil # is 0502884. the coil has the wire inside the coill.Can I use a newer style coil that has the spark plug style tip to conect the wire.The old style you have to srew the wire into the distributer as one unit. By using the newer style coil I can pull the main coil wire on and off like a spark plug wire making life a lot easier for testing or replacing?And if so what part #coil should I use Thaks Tony.
