MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2012
    Location
    Los Angeles, California, United States
    Posts
    3
    Lightbulb 'Whirring' Noise - 1977 Mercury 75/7.5 hp, 2 cyl, 2-stroke
    Hello Everyone.
    I have a 1977 Mercury 75/7.5 hp, 2 cyl, 2-stroke. We call it "the engine that think it can!" She is a beautiful engine thats on our 13 ft Gregor...
    She works great. I cleaned the carb and tuned her up. Her idle isn't too rough.
    After about 1 to 2 hrs of continuous running time, she starts whirring... not in idle but when at 1000 rpms or higher in gear or not in gear. Its puzzling to me because I can't really start to take it apart when we are in the middle of the lake or behind the break wall.
    I do have a subscription for this engine to Seloc Online if needed.
    Any ideas on where to start trying to narrow it down?
    Thanks in advance!
    Q
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,483
    Default Re: 'Whirring' Noise - 1977 Mercury 75/7.5 hp, 2 cyl, 2-stroke
    Without knowing the history of the motor ( was it ever sunk and not recovered properly etc )---It is hard to say.--------------I would start by looking at the lower unit oil.---Any water or metal bits present ??
  3. #3
    Join Date
    Jan 2012
    Location
    Posts
    3
    Quote Originally Posted by racerone View Post
    I took a look at the lower half... I was getting ready to pull it to see if there was water in the oil and i see the lower half leaking oil thats milky between the prop and the lower half body... I think you might be right.... Ill pull it and get back to you.
  4. #4
    Join Date
    Jan 2012
    Location
    Posts
    3
    ok... So i drained the oil. There wasn't any water in it... it wasn't super dark brown and it wasn't like a light coffee... I did notice a leak of milky oil from behind the prop. I think that seal needs to be replaced but I can't seem to figure out how to remove that spanner collar and get to that seal. I am going to replace the oil and if you guys have any idea how to replace that seal I will replace that too
    Thanks again!
  5. #5
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,389
    The "collar" unscrews (lefthand thread). You might have a bad driveshaft bearing.
    Jeff
  6. #6
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,437
    ???? Noises are the hardest to diagnose.Look under the hood and under the flywheel for metal shavings.
    Any color other than black or the original usually means water.
    There are several threads for a homemade pressure tester.Here or on other sites.
    i boats. com , Force Forum use the search function both sites.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
Similar Threads
  1. B-W 73C 'Whirring' Noise
    By k_m_thompson in forum Marine Transmissions and Reverse Gears
    Last Post: 12-05-2011, 09:30 AM
  2. 1977 mercury 4hp 2 stroke starts but cuts out
    By robmcc85 in forum Mercury Mariner Outboard Forum
    Last Post: 08-18-2011, 02:57 PM
  3. Mercury 115 EFI 4 Stroke Noise
    By MERC115EFI in forum Mercury Mariner Outboard Forum
    Last Post: 07-25-2011, 09:17 PM
  4. Replies: 3
    Last Post: 07-10-2011, 09:11 PM
  5. MJDE circa 1977 onan generator noise
    By gwalters in forum Detroit Diesel
    Last Post: 12-14-2008, 04:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
