Click for Honda Manuals, Parts and Model Guides!
Results 1 to 2 of 2
  1. #1
    Post both engines stalling when reversing engines
    when I am pulling into a slip at low RPMs ( idle speed ) and pull the throttles into reverse to stop , both engines stall creating a safety issue .
    although my Honda 130's are 10 yrs . old , I have them fully serviced each year . I had new steering cables replace last year as well .
    Any recommendations are most welcome !
    daveonboard
  2. #2
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,751
    Default Re: both engines stalling when reversing engines
    Sounds to me as if your idle speed settings on one or both engines may be set too low allowing the the engines to "lug" as you're maneuvering at low speed forward. When you put the additional "braking" load of reverse on, they just aren't keeping up and are falling below the RPM threshold to stay running. If this condition sort of came on gradually, it could be a fuel delivery issue. If it started suddenly or about the same time the steering cables were replaced, it could be an adjustment problem.
Similar Threads
  1. CM6-55 Engines
    By mcgpm in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-29-2016, 07:37 AM
  2. MWM engines
    By jeff in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 02-03-2015, 10:20 AM
  3. Engines
    By redsnapper386 in forum Mercruiser Sterndrive Archive
    Last Post: 08-27-2009, 06:31 PM
  4. 260 engines
    By atilla_boy in forum Mercruiser Sterndrive Archive
    Last Post: 10-21-2008, 01:17 AM
  5. MWM GAS ENGINES
    By VIMO TRADING CO in forum Archive 2002-2006
    Last Post: 08-19-2001, 11:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
