Hi Folks, I'd appreciate any help and info on the attached reverse gear. It came attached to an Andres Marine 1955 Packard 320 cid V8 marine conversion motor that I acquired at Ladd's Boat Yard in Stockton CA. No casting numbers or data plate are present. I'd like to get some idea of the Mfg, year, correct lube fluid and capacity, etc. Also need a new top cover gasket if available. It is a 1:00 to 1:00 ratio with a 1 inch shaft collar.
Thanks in advance,
John
Thanks in advance,
John
