352 Interceptor pump impeller
Ayuh,... If yer talkin' 'bout the raw water pump, it's probably got a name or numbers on it, as it wasn't built by Ford...
1960 - Ford Eaton 352 Interceptor???? Wow, that's going back a few years.
Perhaps there is a good way to adapt a more current sea water pump!!!!!
I'm making this suggestion because this 1960 pump body itself may be worn too severely for a new impeller alone to work correctly.
The cam and the two thrust surfaces must be in pretty darn good condition, or a new impeller just may not cut the mustard.
I say Pictures! Post a few pictures!
