MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 11 of 11
  1. #1
    Join Date
    Jun 2010
    Location
    Queensland Australia
    Posts
    212
    Default Steering cable seized
    I bought a new cable earlier this year and haven't had any problems with it at all. For the last week we have had an unusually large amount of rainfall and today I found that the steering cable on my boat is seized. I last used the boat about 6 weeks ago so I was quite surprised (shocked) to find that it no longer works. I removed the cable to isolate the problem (cable or pivot bearings) and found that it is most definately the cable. How do I resurect this cable? Is there anything I can do? My boat is not kept under cover (inside a shed etc) but I have had it covered with a synthetic sheet (tarp in Australia) that has been doing a great job of keeping the rain out of most of the boat, or so I thought.
    Mariner 55hp twin cylinder twin carb (Japanese Mariner) running 60hp carbs cause that's what I had handy.
    Crest Craft 4.5m/15' half cabin
    Qld Australia
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,440
    Default Re: Steering cable seized
    It's a messy piece of work, but you can remove the inside part of the cable, clean and lube everything, and stick back together. It should then work like new IF it's not kincked.
    Jeff
  3. #3
    Join Date
    Jun 2010
    Location
    Posts
    212
    There are no kinks that I can see from the outside, it's a very straight forward path from the helm to the outboard in my boat. How do you disassemble the cable?
    Qld Australia
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,464
    FIRST!!!!! NO HAMMERS!!!
    The end of the cable will mushroom out and it will not come through the steering tube.
    Get someone inside the boat. While you push on the motor, one way or the other have someone turn the wheel.
    Maybe a small bit of heat.
    Once it comes loose.Use white lithium or a spray oil.
    Most greases when you add salt water will gunk up and make it hard to steer.
    I keep a can of WD-40 in my boat and spray the steering arm and moving parts EVERY time I go out.
    Use a white lithium based marine grease on your other grease fittings.
    You can't disasemble the cable.J
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  5. #5
    Join Date
    Jun 2010
    Location
    Posts
    212
    It seems I got lucky. The recent week of rain must have been the cause because the fix was quite simple. I was able to spray a similar lubricant to WD40 along the outboard end of the cable which with gravity assistance made it way inside the sliding tube and loosened whatever was causing the binding. With a small but adequate number of light strikes to the cable end with a rubber mallet the obstruction was released. The steering wheel turned ever so slightly in one direction before a slightly forceful turn in the other direction had everything moving like new. Continual application of water disspersant seems to be the order of the day from now on.
  6. #6
    Join Date
    Sep 2010
    Location
    louisiana
    Posts
    76
    Just a thought...By any chance did you grease the hinge on the upper part of the lower unit??? One or twice a year I put a couple a shots of grease on the side to side hinge and also to the up and down hinge...BF
  7. #7
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,464
    ANY kind of hammer can damage the end of the steering cable.Even rubber.
  8. #8
    Join Date
    Mar 2011
    Location
    northern IL.
    Posts
    78
    I've had the same problem with the steering cable on my boat, and fixed it nearly the same way . The only thing that I did diffrent was to take a wooden dowell rod (3/8") amd cut a slot down the center about 4" long, placed some emery cloth in the slot, and roll, it to act as a flapper wheel in a drill and polish the inside of the tube after i had cleaned out all the grease. Then replaced everything with a grease coating, and grease all the pivit points and tube wiht good marine grease. When you grease the slide shaft on the steering cable make sure that the shaft is all the way retracted in the tube. That way you cannot cause a hyrodrlic lock in the tube. Replace the tube nut as there is a rubber seal in them that can go bad also. Never hit the tube rod with any type of hammer! Use a nylon rod or a brass rod as a punch if you ever do, and always put the WD 40 in the cable side of the tube, with the trailer blocked up, in order to keep the penatrant from going back up the cable unless it is causing the problem.
    Have FUN boating and BE SAFE,
    oldman570
  9. #9
    Join Date
    Jun 2010
    Location
    Posts
    212
    Quote Originally Posted by BIGFLAT View Post
    I grease all the pivots every second or third outing, probably over kill but that is what I have got into the habbit of.
  10. #10
    Join Date
    Jun 2010
    Location
    Posts
    212
    Quote Originally Posted by oldman570 View Post
    oldman570
    That sounds like a good way of sorting things out, I used a rag tied into a length of rope and used it like a rifle/gun barrel pull through. I don't think it cleaned it up as well as it could be using your method.
  11. #11
    Join Date
    Jun 2010
    Location
    Posts
    212
    Quote Originally Posted by Jerryjerry05 View Post
    That sounds like a good preventative maintenance tip. When I bought the cable I was advised (by the sales bloke - should have known) never to lubricate the cable. It sounded crazy but I'm new to all this boating stuff, sounds like grease should never be used though.
Similar Threads
  1. Steering seized 1969 80 hp 800
    By haventaclue in forum Mercury Mariner Outboard Forum
    Last Post: 01-15-2010, 11:47 AM
  2. Seized steering yamaha 6h3 70beto
    By strapper in forum Yamaha Outboard Archive
    Last Post: 11-26-2008, 06:48 AM
  3. CABLE BUDDY%e2%84%a2 Steering Cable Lubrication System
    By pas_bon in forum Yamaha Outboard Archive
    Last Post: 11-24-2008, 06:42 AM
  4. Steering cable
    By hunter_11689 in forum Mercury Mariner Outboard Archive
    Last Post: 04-27-2006, 09:22 AM
  5. Mercury 199290hp 3 cylinder two stroke seized steering
    By bill in forum Outboard motors archive 2000-2004
    Last Post: 10-04-2001, 08:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
