Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 5 of 5
  1. #1
    Join Date
    Mar 2011
    Location
    South Africa
    Posts
    122
    Default Unleaded fuel in old boats
    Hi, anyone know if old two strokes can run on unleaded? If so, what changes to be made to achieve this?
  2. #2
    Default Re: Unleaded fuel in old boats
    they will run you didnt say what year? you can buy lead additive in any part store mix as needed i use it in my 1976 harley seems fine .unleaded fuel really only afects the valve guides 2 strockes no guides
  3. #3
    Join Date
    Mar 2011
    Location
    South Africa
    Posts
    122
    1983 DT115, ran it on 93 unleaded today, ran well. Even used less fuel than it usually does. Didn't use any additives. Ran three tanks so if someting was gonna fail or break it would have by now. Didn't alter timing or anything! Sweet!
  4. #4
    unleaded is no problem . E10 is quite an issue and i wont run the engine on that
  5. #5
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,266
    Unleaded NO problem.They said it increases the temp and helped with the valves.
    Like Junebug said no valve guides in an outboard.
    Ethanol is another pain altogether.
    It actually is burning hotter and contains water.
    Since it's mixing with oil it's not so bad but the water is a bummer.
    The oil/gas can/does seperate faster than it used to.
    So add Ethanol additives if your gonna let the gas/motor/boat/mower set any length of time.
    Get towing insurance.Great investment.
    88 Bayliner with twin 85's
Similar Threads
  1. Unleaded or leaded mix
    By waldoh in forum Mercury Mariner Outboard Archive
    Last Post: 10-06-2009, 09:10 PM
  2. Unleaded fuel
    By william0064 in forum Volvo Penta Gas Archive
    Last Post: 08-30-2008, 01:40 PM
  3. Help with leaded or unleaded fuel
    By mike12 in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-06-2007, 04:27 PM
  4. Leaded or unleaded fuel
    By alan the roofer in forum Johnson Evinrude Outboard Archive
    Last Post: 02-21-2007, 08:34 PM
  5. Unleaded fuel for 1982 Johnson 70HP
    By Darren Wilson in forum Johnson Evinrude Outboard Archive
    Last Post: 03-08-2004, 01:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
