Results 1 to 8 of 8
  1. #1
    Default How to set timing on a 2000 johnson 175
    How do you set the timing on a 2000 johson 175 , it's has carbs.... Thanks ...
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,515
    Default Re: How to set timing on a 2000 johnson 175
    Ignition timing is factory set and should not be adjusted / messed with.-----------------Is there a reason why you might suspect " timing is not right " , running problems with the engine ???
  3. #3
    I replaced the optical sensor, I didn't mess with timing, the timing should not have changed ... right? the engine runs great, just wont to make sure its right...
  4. #4
    Join Date
    Apr 2010
    Posts
    3,897
    Any time you change an electrical component on a mtr that has to do with the ignition system the timing should be verified. Any good dlr should have the tool to do this and it can be set statically. Takes all of about 15 min to do it.
  5. #5
    Is it a Ficht with electronic ignition? If so, you need the software from BRP, a laptop with a serial port, a serial cable for the motor, and a timing light. It's really easy to do. You run the software in the test mode and select the timing function. When you go into this mode, the software locks the timing. It will then tell you where it thinks the timing should be. With the timing light on (connected to cyclinder 1), you watch where the timing light shows up on the flywheel. You then adjust the angle using the software to match what it actually is. There's a good explanation in the help section of the software.
  6. #6
    Thanks for the reply, its not a Ficht... I know how to set the timing on a auto with a timing light, is it the same? do you know what the rpm should be set at idle and someone said it should be 4-6 atdc at idle and at 18 btdc at 5000 rpms.. is this right? Thanks....
  7. #7
    Join Date
    Apr 2010
    Posts
    3,897
    Your idle rpm is dependent on what the idle timing is and should be set at 600-700 rpm in gear. This of course depends on mtr condition. Don't set your wot timing on muffs as a rod might come out and kiss you. Your specs are correct.
  8. #8
    Thanks for the info......
Similar Threads
  1. 90 hp johnson timing
    By clayvogt in forum Johnson Evinrude Outboard Archive
    Last Post: 04-28-2009, 05:48 AM
  2. 2000 Sea Fox W 2000 150 HP Johnson motorPlease Help
    By cmone42 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-11-2008, 07:24 PM
  3. Help 2000 57 GSI Timing Marks
    By monterey262 in forum Volvo Penta Gas Archive
    Last Post: 04-08-2007, 08:35 PM
  4. 2000 Horizon 57 L MPI Mag timing
    By Larry K in forum Mercruiser Sterndrive Archive
    Last Post: 09-04-2006, 09:04 PM
  5. Timing on Johnson
    By ram in forum Johnson Evinrude Outboard Archive
    Last Post: 03-31-2004, 05:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
