MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
  1. #1
    Default float needle valve
    Hey all, Have a question about carb kit i just bought. The old needle valves have the rubber tips to seat it . The new kits come with stainless steel ones , no rubber tips. Is this acceptable as replacments? Seems years ago you had brass seats and ss needle, but the seats were replaceable too. These seats are not. 2000 90hp merc. 2-stroke 3-cyl. Carb kit Sierra# 18-7750. Thanks for any input
  2. #2
    Join Date
    Apr 2008
    Location
    San Jose, CA, USA
    Posts
    210
    Default Re: float needle valve
    If the seats are clean, the size of the valve tips are correct, you will have no problem with either rubber tips or stainless tips or?
    Good luck.
  3. #3
    GHN; Thanks for your response
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,389
    Mer did it both ways, with the rubber tipped needle design the later method (which would suggest it's superior). Just don't mix them up and all will be well!
    Jeff
    PS: I "vise test" carbs that I rebuild before bolting them on the motor--much easier to fix 'em that way! Hook a fuel line to the carb and pump her up good. If she leaks a tiny bit (or not) that's okay, but if you have a gusher lower the float level a 1/16 of an inch and try again.
  5. #5
    Thanks fastjeff. I will definetly do the test.
Similar Threads
  1. 94 175 needle valve adjust
    By rich_p in forum Johnson Evinrude Outboard Forum
    Last Post: 07-12-2011, 10:25 AM
  2. Does 1959 Evinrude 5.5 HP Float Needle need a spring?
    By polefroggy in forum Johnson Evinrude Outboard Forum
    Last Post: 02-20-2011, 09:26 PM
  3. Stuck needle valve
    By zephyr07 in forum Yamaha Outboard Archive
    Last Post: 03-04-2008, 07:19 PM
  4. Fix a needle valve
    By eurekan in forum Johnson Evinrude Outboard Archive
    Last Post: 08-18-2007, 05:50 PM
  5. Needle Valve Assembly 37L 165
    By vkeiper in forum Mercruiser Sterndrive Archive
    Last Post: 07-23-2006, 09:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
