Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 8 of 8
  1. #1
    Join Date
    Apr 2011
    Location
    san pedro sula,honduras
    Posts
    3
    Post fuel oil ratio chrysler 9.9hp outboard model 95h3j
    Hello how are you, I hope I can explain it , I understand very little English. the question is :what fuel oil ratio should I use in my outboard motor? I have tested with 50:1 but a lot of smoke and i need to know where is my problem? I read that there is 100:1 ratio but need to be sure not to cause damage to the engine, I look forward solution as I have not found anything regarding this engine model. thank i hope your answer soon.
  2. #2
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    317
    Default Re: fuel oil ratio chrysler 9.9hp outboard model 95h3j
    I bought a small bottle of AMSOIL 100:1 once but never had the guts to try it. Another thing
    an old Chrysler dealer told me once was NEVER use the oil made by the after market, even big
    name brands like Pennzoil, Gulf, etc. They cause too much carbon build up unlike the OEM
    oils.
    Mercury Quicksilver 'Premium' 2-cycle has noticeably less smoke than any other 2-cycle oil
    I've seen. I use in everything now even my lawn mower and snowmobile.
    It's not real cheap but says what it does unlike other 'smokeless' oils and for
    how much fuel you'll be burning especially if your going to troll a lot it's
    worth it.
    Jack
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    12,771
    Run at 50:1 if you want your motor to last !!!
  4. #4
    Join Date
    Apr 2011
    Location
    Posts
    3
    Quote Originally Posted by 300hb View Post
    oils.
    worth it.
    Jack
    thanks , i'll try with other kind of oil or other brand
  5. #5
    Join Date
    Apr 2011
    Location
    Posts
    3
    thanks ,i'll take your advice
  6. #6
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,256
    The older outboard oils before TCW3 were not designed very well.The original outboard oil was actually designed to burn and carbon the cylinders and rings.
    It took till TCW3 till they got it right.
    Use any oil you want.
    Amsoil is without a doupt the best also the most expensive.
    I use it on other peoples stuff!!
    You should de-carb with Seafoam or Power Tune at least once a year.
    PM should be done all the time with an outboard.
    I've seen people use a spray bottle with water in it to help remove carbon from the cylinders.(dont think I would).
    Get towing insurance.Great investment.
    88 Bayliner with twin 85's
  7. #7
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    317
    While where on the subject... I was told by a Rokon tech that 24:1 is the
    'sweet' spot for the Power Bee engines.
    I took that as possibly having an effect on 2-cycle's in general for more compression and performance. Sound plausible to anyone....???
    Jack
  8. #8
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    317
    Quote Originally Posted by guimape View Post
    I forgot it's the Premium 'PLUS'. There is a difference and although it cost twice as much as the regular 'Premium' it's worth it!
Similar Threads
  1. Chrysler model 35601 fueloil ratio
    By bonanzadriver in forum Chrysler Force Outboard Forum
    Last Post: 09-24-2009, 06:41 PM
  2. GasolineOil ratio for Chrysler 36 HP outboard 1977
    By tony_v in forum Mercury Mariner Outboard Archive
    Last Post: 06-30-2006, 08:50 AM
  3. Chrysler 4hp cooling amp Fuel ratio
    By gregbick in forum Chrysler Force Outboard Archive
    Last Post: 04-17-2006, 05:53 PM
  4. Mix ratio for Chrysler 99 hp model 92H1H b80 or b81 I think
    By Brian Handley in forum Chrysler Force Outboard Archive
    Last Post: 10-19-2003, 10:28 PM
  5. Chrysler 35 looking for year and fuel ratio
    By brian in forum Chrysler Force Outboard Archive
    Last Post: 04-15-2003, 11:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
