Results 1 to 4 of 4
  1. #1
    s.shaw's Avatar
    s.shaw Guest
    Default is it possible to marinize a
    is it possible to marinize a standard lorry engine
  2. #2
    C. Vindriis's Avatar
    C. Vindriis Guest
    Default " Yes it is possible, but it i
    " Yes it is possible, but it is a heap of work, you are better off to marinize an industrial engine as these usually have govenors already installed.
    The alternative is to find a motor that is available as a marine engine and buy the marine bits, heat exchanger, govenor, etc.
    Anything is possible but frequently not worth the cost to create an orphan.
    I guess you are from the UK. (Lorry is so English).
    Cheers Claus in New Zealand. "
  3. #3
    John Hulburt's Avatar
    John Hulburt Guest
    Default I have a SD25 Nissan Deisel th
    I have a SD25 Nissan Deisel that is almost converted to marine use for a 36" Cape George Sailboat . I've just aquired this setup and i'm not sure what I have or where i can buy a manual and parts for this orphan .
  4. #4
    Join Date
    Aug 2009
    Location
    Port Townsend, Wa., USA
    Posts
    29
    Default Re: Marinizing a diesel engine
    I believe Nissan makes a marine diesel. and other marine engine brands like Volvo or Mercruiser may marinize them.The difference is that the automotive engine turns LH and standard marine turn RH so getting a reverse gear/ reduction gear for it must consider that. some Hydraulic gears are reversible with minor part changes. Also automotive gaskets often have carbon in them and it promotes electrolytic corrosion. I am not aware that it would need a governor unless it is for a gen set. A heat exchanger would be desirable but It could be raw water cooled. [much reduced engine life]. there are other technical differences in tuneing torque etc. But the engine should be usable.
    t
Similar Threads
  1. I have sighted a Detroit Diesel 451 Marine Diesel engine in Mobile AL
    By Daniel F. Blanchard in forum Detroit Diesel
    Last Post: 07-27-2016, 07:09 PM
  2. Marinizing a B230 to replace a siezed AQ131A
    By madmallard in forum Volvo Penta Gas Engine Forum
    Last Post: 05-10-2016, 10:52 PM
  3. Marinizing HEI
    By hystat in forum Mercruiser Sterndrive Archive
    Last Post: 08-23-2008, 07:54 AM
  4. 4 stroke diesel engine vers a 2stroke diesel
    By john motta in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-20-2008, 02:16 PM
  5. BMW DIESEL ENGINE
    By Anonymous in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 12-14-2000, 05:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
