MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 4 of 4
    Default 1992 DT 40 -- Power Tilt SLOW
    When the motor goes up it's very, very slow and weak, and then it bleeds down fast.
    I've checked the hydraulic reservoir, and it's full. And there are no visible external fluid leaks.
    Any help would be HUGELY appreciated.
    May 2010
    Sebastian ,Fl
    1,273
    Default Re: 1992 DT 40 -- Power Tilt SLOW
    If the T/T leaks down it's usually the hydraulic pump.
    The manual should have leak down tests to diagnose the problem.
    My library has a section with outboard repair books.
    Or send a note to Suzuki service.J
    PARDON THE WRITING, FOR SOME REASON I CAN'T USE PARAGRAPHS. THE SENTANCE'S ALL RUN TOGETHER !!!Ethanol is messing up a lot .It's delaminating the inside of older hoses causing clogs in the carbs/injectors and fuel filter.
    Oh yea DON"T buy any parts from boats . net Worst company on the net.
    Sep 2010
    ontario
    7,438
    Is the tilt motor working properly ????--------------Is the manual release screw tight ???
    There's no trim, just tilt. I don't have a manual, and the schematics on brownspoint.com are, while appreciated, not always accurate.
    The tilt motor is working fine, and the release screw is tight. However, I saw on an iboats.com forum post a reference to the two tiny seals in the manual relief valve. I'll go ahead and look into those next, if that turns out to be the problem I'll post it.
    Thanks for your help.
  1. Replies: 2
    Last Post: 07-30-2011, 05:18 PM
  2. 1992 Evinrude 40 hp power tilt
    By MSFisher in forum Johnson Evinrude Outboard Forum
    Last Post: 07-07-2011, 03:37 PM
  3. 1992 Mariner 40hp Magnum Trim Tilt Slow Fall
    By Jake_MN in forum Mercury Mariner Outboard Forum
    Last Post: 07-11-2010, 08:19 PM
  4. 1992 115 mercury power tilt
    By yap_yap in forum Mercury Mariner Outboard Archive
    Last Post: 11-10-2009, 05:41 AM
  5. Slow when tilt down
    By fireguy in forum Mercruiser Sterndrive Archive
    Last Post: 09-01-2007, 05:50 PM
