Click for Ford Lehman manuals!
Results 1 to 6 of 6
    Apr 2008
    vancouver, bc, canada
    11
    Default Changing the oil pan gasket on a 2715e
    I am leaking oil from my oil pan gasket. Is it a very big job to just drop the oil pan and re&re the gasket. Are there any " gremlins " that might ruin my day? I have about 8" below the
    oil pan to work with interms of vertical space. It is quite tight with respect to the bulkheads that surround the area below the engine. I can get a ratchet to all the bolts. What type of gasket sealent do guys on this forum recommend ?
    Default Re: Changing the oil pan gasket on a 2715e
    Graham,
    are you sure the rocker cover or lift pump gaskets aren't leaking?? Is it possible you have more than 13 quarts of oil in the sump ??
    It takes two people to remove the sump and carefully install it. If you decide to go that route i will tellyou the proceedure if you do not have a manual.
    Charlie w
    Apr 2008
    11
    I completely cleaned the bilge and laid new absorbant pads. I then ran the engine for about 45 min. There was only one new oil stain on the absorbant pad. I then felt direct above this and felt a oil drip. It was by one of the bolts that is holding on the oil pan. I am going to clean the out side of the engine again and repeat this procedure till I am sure. Does this make sense?
    Graham,
    i would find the leak just as you are doing.
    You didn,t mention the locatoin of the bolt , such as port or starboard side, fore or aft and what is right above it ??
    Do you have a lehman conversion ??
    Charlie w
    What's Ford 2715e oil capacity ?
    thanks
  6. #6
    Jaro, crankcase holds 13/15 quarts including oil filter charlie w
  1. 2715E engine
    By rbwuth in forum Ford Lehman
    Last Post: 10-22-2010, 02:55 AM
  2. 2715e wiring
    By ebgb in forum Ford Lehman
    Last Post: 10-03-2008, 11:01 AM
  3. FORCE 120 WATER IN CYLINDER STILL AFTER CHANGING HEAD GASKET
    By BOB HANSEN in forum Archive 2003-2009
    Last Post: 06-11-2006, 06:31 PM
  4. FORCE 120 WATER IN CYLINDER STILL AFTER CHANGING HEAD GASKET
    By BOB HANSEN in forum Chrysler Force Outboard Archive
    Last Post: 04-20-2004, 12:13 AM
  5. FORCE 120 WATER IN CYLINDER STILL AFTER CHANGING HEAD GASKET
    Last Post: 04-19-2004, 04:23 PM
