Results 1 to 3 of 3
  1. #1
    Larry B.'s Avatar
    Larry B. Guest
    Default " I have a stock OMC aluminum
    " I have a stock OMC aluminum 17 pitch prop to do some skiing, but it has too much over rev. this motor is on a 20' bow rider. I need more top end and i want to get a stainless prop anyway. what kind of performance prop should I get? What diameter will fit this engine and is a 4 blade better then a 3 blade? "
  2. #2
    Default " for a skiing i would suggest
    " for a skiing i would suggest getting a 4 blade because the 4 blade gets you on top quicker, or go to a stainless 3 blade and get a hydro-foil, either would work for better preformance for skiing "
  3. #3
    Join Date
    Nov 2005
    Location
    Posts
    424
    Default " Larry, Check out th
    " Larry,
    Check out the michigan wheel website.. I believe it's www.miwheel.com , if you poke around enough they have a prop calculator that will take the make and model engine and the boat and spit you out an esimated prop selection.
    Jon "
Similar Threads
  1. 1999 Johnson 40hp prop
    By omc_10 in forum Propeller Selection and Replacement
    Last Post: 04-27-2010, 10:23 PM
  2. Prop help selection
    By trkman in forum Mercury Mariner Outboard Archive
    Last Post: 09-10-2009, 04:22 PM
  3. Prop selection
    By sa_cop in forum Johnson Evinrude Outboard Archive
    Last Post: 04-01-2009, 07:22 PM
  4. Prop selection
    By joecrow in forum Mercury Mariner Outboard Archive
    Last Post: 07-27-2008, 03:33 PM
  5. Prop selection
    By goose in forum Volvo Penta Gas Archive
    Last Post: 09-17-2006, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
