Gday my names martin ive just come across this forum in search of info on a new motor ive just perchased(new to me lol)
I currently own a lewis tornado ski boat with an 83 johnson 200hp donk on it.Which is half way pulled down due to it being low on compression and very tired i was originally planning to rebuild her but i stumbled across an 89 johnson 225hp vro looper and was just wanting to know if anyone has some info i should need to know about these.I went and checked it out today ran a comp check on it 4 cylinders were at 90psi and 2 were at 85psi i warmed motor up first but completely forgot to have the throttles open will this make a huge differeance.the motor looked to be in really good nick also pump water nicely. no rust or corrosion trim worked beautifully.Just wondering if those numbers sounded ok ive read that they were only 100psi from factory is this correct????Also its vro has been disconnected also the power steering??which i only found out they had because it said it on the cowling and i am very interested on info on that part of things as well.I got it for $2500 aus dollars just wondering what opinions are of these engines ill post some photos of my boat and engine shortly. and what performance gains do you think i will see with this compared to the old 83 crossflow 200hp i know alot of factors change this.Ok ill stop rambling on for my first post lol looking forward to your replies![]()
