Results 1 to 8 of 8
  1. #1
    Join Date
    Oct 2011
    Location
    Laingsburg, MI
    Posts
    16
    Default 50HP Johnson J50PLSI Spark on 2 not on 1....how to trouble shoot.....just started!
    I have a 2000/2001 Johnson 50HP. It had been running fine. Then it started missing, vibrating and being hard to start. We have a very very weedy lake and do have to "clear" the lower transom alot. Very recently I noticed the I was only getting 1/2 power. Put new plugs in and will get 60-70K rpm in "idle" but under load about 40K rpm is all it will go. So I figured must be a bad cylinder. Did a compression check and have 120 in both, very nice and even. I have one dark plug, the other is clean as a whistle. Switched plugs and wires. It is the spark that isn't getting to the top plug. Any ideas on what to check up-line?
    Thanks and new to the forum. Hopefully not insulting anyone.
  2. #2
    Join Date
    Oct 2011
    Location
    Laingsburg, MI
    Posts
    16
    Default Re: 50HP Johnson J50PLSI Spark on 2 not on 1....how to trouble shoot.....just started!
    How do I identify the sensor coil? Is there one per plug/cylinder or just one overall?
  3. #3
    Join Date
    Mar 2012
    Location
    Columbus MS
    Posts
    39
    I'd start with the illustrated parts list, it shows a picture of the items and if you scroll down the parts list, it will tell you how many are needed. If I have your motor selected correctly, there is one stator, one sensor coil, one power pack and one coil assembly. All 4 of these work together to provide the spark to the spark plug. The best thing to do is to get a shop manual for your motor and use it to test the components so you can rule out the bad part.
  4. #4
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Check this thread:
    http://www.marineengine.com/boat-for...the-power-pack
    However reving your engine to 6-7K on idle is a sure way to get it severely damaged!! Hardly any fuel needed = no oil for lubrication!!!!!!!!!!!!
  5. #5
    Join Date
    Sep 2010
    Posts
    19,078
    2 sensor coils I believe.----------Switch the small wires at the coil and see what happens to spark.-----If you check you may be able to switch / jumper the wires and try to make sensor coil #1 fire coil # 2.-------Once that is done you can decide.-------------Or if you have an ohmeter you check ohms on the 2 sensors and compare them.---------My bet is a faulty powerpack.
  6. #6
    Join Date
    Oct 2011
    Location
    Laingsburg, MI
    Posts
    16
    Have made sure oil supply and compression are fine. Have ordered a new power pack. I will post a resolution if that is it. I cleaned all leads, ground connections and all of the terminal bar strip connections, nothing changed. I really appreciate all the input.
  7. #7
    Join Date
    Oct 2011
    Location
    Laingsburg, MI
    Posts
    16
    Replaced the power pack same problem missing spark on top cylinder. Good spark on lower cylinder. Tested at night no shorts seen.....what might be next...ignition coil????
  8. #8
    Join Date
    Oct 2011
    Location
    Laingsburg, MI
    Posts
    16
    Turns out that the trigger was bad and fried both power packs. So new trigger, new power pack and firing on both cylinders. Proper diagnosis with the right tools would have saved me a BUNCH of $$$. I was rushing a little and paid for it.....literally!
Similar Threads
  1. Replies: 2
    Last Post: 09-24-2011, 04:54 AM
  2. Force 50hp - Starts great cold. Have to throw in gear to get started when warm
    By fickesd in forum Chrysler Force Outboard Forum
    Last Post: 09-08-2011, 05:09 PM
  3. Johnson 50HP 1988 No spark
    By anders in forum Johnson Evinrude Outboard Archive
    Last Post: 11-09-2008, 03:59 AM
  4. Trying to trouble shoot clogged fuel system
    By punkyboater in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-12-2007, 11:31 PM
  5. 1971 johnson 85hp hydro electric drive spark trouble
    By rockinron in forum Johnson Evinrude Outboard Archive
    Last Post: 05-25-2006, 09:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
