Results 1 to 6 of 6
  1. #1
    Default 1988 5.7 OMC NEW exhaust manifolds?
    Hi Guys,
    New to the forum. I'm in the process of replaceing my exhaust manifolds, and risers on my 1988 Bayliner 5.7 OMC engine. I puchased a set of new Barr brand manifolds and risers. I started by removing the paint from the risers mounting surfaces, then started on the exhaust manifolds, riser mounting surfaces,and noticed that they didnot compare to the old ones I took off. The old ones being replaced before by other owners, 1 was a GLM brand, the other a OMC brand. Any way the concern I have, is the surface on the new exhaust manifolds where the risers mate on the surface, on 1 exhaust manifold where the cooling section is next to the main rectangular exhaust port, coming up throughClick image for larger version.
ID:	3386Click image for larger version.
ID:	3387Click image for larger version.
ID:	3388 the center next to the corner, next to the bolt mounting hole is closed off by casting with no gap at the surface, and goes down in the cooling section 1 1/4" to 1 1/2" solid. The other new exhaust manifold, is the same way only all 4 corners in that area are closed off? (see pictures #1 and #2.) The old manifolds(#3 picture) are open all the way around, the exhaust center port. My concern is the reason I'm replaceing these manifolds, because of rust and corrosive build up. Then the new ones already have blocked off cooling sections to begin with.
    Also I'm wondering if in that section, with no gap, there might be hot spots where the heat from the exhaust does not have time to disipate. I have contacted the place I purchased the exhaust kit from, but they say they contacted Barr Mfg. and said there is no problem, and also asked their in store mechanic, and he said no problem.
    If that is so , why does the old exhaust manifolds have no castings in that area. I think that Barr Mfg. needs to clean up their molds. I went with Barr Mfg. because USA made now I'm wondering.
    Thanks for any help on this matter.
  2. #2
    Default Re: 1988 5.7 OMC NEW exhaust manifolds?
    Send it back and get another one.
  3. #3
    Join Date
    Aug 2011
    Location
    MI
    Posts
    54
    What do the gaskets look like?
  4. #4
    Quote Originally Posted by Master mechanic View Post
    HI, They say, all of theirs are the same as the ones I have.
  5. #5
    Hi, The gaskets are new, they go between the riser elbow and the exhaust manifold surface, but thats not the problem.
  6. #6
    I never had a problem with osco. Send them back and get your money back they are defective.
Similar Threads
  1. 440 Exhaust Manifolds
    By supra_beast in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-18-2009, 03:44 AM
  2. OMC 460 Exhaust manifolds
    By baykrboy in forum OMC Sterndrive and Inboard Archive
    Last Post: 10-07-2008, 10:19 AM
  3. Exhaust manifolds for OMC
    By artic429 in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-07-2008, 03:41 PM
  4. Replace OMC 43 exhaust manifolds with Volvo 43 manifolds
    By chris_f in forum OMC Sterndrive and Inboard Archive
    Last Post: 02-27-2007, 12:36 AM
  5. Exhaust Manifolds
    By Jason Blue in forum Archive 2003-2009
    Last Post: 07-13-2003, 09:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
