Results 1 to 8 of 8
  1. #1
    Join Date
    Dec 2010
    Posts
    109
    Default OMC Tilt Gauge Sending Unit (1989) 110HP 2T
    Hello.
    What sending unit do i need for this OMC trim guage?
    I have looked online, but do not know if I am looking at the right sending unit.
    I already have the OMC trim guage, but need the sending unit to go with it.
    Help?
    Cameron
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,316
    Default Re: OMC Tilt Gauge Sending Unit (1989) 110HP 2T
    Are you sure that your engine does not already have one? It would be attached to the inside top portion of the port transom bracket.... a black component with a spring loaded black lever protruding from it. Par Number 583358.
    We occasionally have questions. If you fail to answer, it may affect ours.
  3. #3
    Join Date
    Dec 2010
    Posts
    109
    will check
  4. #4
    Join Date
    Dec 2010
    Posts
    109
    OK - just checked, and yes this sending unit is still present.
    I am curious how this 'talks' to the gauge?
    What moves and what does this sending unit detect to it's guage and how does it do this?
    Cameron
  5. #5
    Join Date
    Feb 2001
    Location
    Posts
    14,316
    The spring loaded lever (unless it's stuck and faulty) moves up and down as the engine swivel bracket presses against it. This changes the ohm resistance within it which in turn causes a related reflection of the gauge. A wiring diagram would be a big help, probably available via this site and its members. If your sender is good, the up and down movement of that black lever will result in a smooth movement reading of your ohm meter. If good, you saved about $100.
  6. #6
    Join Date
    Dec 2010
    Posts
    109
    thanks - any way to maintain or ensure smoothness of that black lever?
    cameron
  7. #7
    Join Date
    Feb 2001
    Location
    Posts
    14,316
    I don't fully understand that question. If the lever is sticking, you might spray some WD40 on it hoping it frees up. Normally they remain trouble free until dooms day.
  8. #8
    Join Date
    Dec 2010
    Posts
    109
    thank joe
Similar Threads
  1. 115 Merc 4Stroke no trim sending unit for gauge
    By leros in forum Mercury Mariner Outboard Archive
    Last Post: 06-17-2009, 02:07 PM
  2. Trim gauge sending unit bad
    By leros in forum Johnson Evinrude Outboard Archive
    Last Post: 06-30-2008, 11:06 AM
  3. Temp gauge sending unit problem on 360 v8
    By lottanerv in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 03-05-2008, 04:44 AM
  4. Trim Gauge Sending Unit
    By billyg in forum Outboard motors archive 2000-2004
    Last Post: 09-14-2001, 10:52 AM
  5. Temperature gauge sending unit
    By marty whittemore in forum Outboard motors archive 2000-2004
    Last Post: 06-18-2001, 09:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
