DavidW2009
I have a carburetor flow meter that reads the volume of air taken in at each carb while it's running at idle speed. Obviously, this meter is no good for anything above idle.
The meter reads in dm(cubed) per minute. And I was wondering if marine mechanics use an instrument like this for diagnosic purposes. And how it could be used to diagnos the health of a motor.
I tried it on my 90 HP Chrysler at idle.
Background on the motor:
Compression:
Top: 135 lbs.,
Middle: 133 lbs.,
Bottom: 135 lbs.
Flow meter readings: (dm = decimeters)
Top: 1950 dm (cubed) per min., (69 cu. ft/min)
Middle: 2050 dm (cubed) per min., (75 cu. ft./min.)
Bottom: 1950 dm(cubed) per min. (69 cu. ft./min.)
I was wondering if a problem with the reed valves could be detected using this??
Attached is a photo of the meter. It's made in West Germany.
Compression:
Top: 135 lbs.,
Middle: 133 lbs.,
Bottom: 135 lbs.
