MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default 1979 Mercury 40hp 402 2 cycle
    I'm having a problem with my carburetor leaking fuel out of the float bowl when you pump the ball.
  2. #2
    Join Date
    Nov 2005
    Location
    Chesapeake, Va, US
    Posts
    1,111
    Default Re: 1979 Mercury 40hp 402 2 cycle
    You need to rebuild the carb. Clean thoroughly and reassemble using new gaskets, needle and seat. Be sure to check the float while you have it apart for fuel intrusion and adjusted properly when reassembling.
    Bill H PTC USN Ret
    A manual is a cheap investment.
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,428
    You can hand pump that carb to 15 pounds pressure, where the motor only develops 4. Most carbs will do that if you pump too hard. Long as it doesn't leak when the motor is running it's okay.
    Jeff
    PS: I lower the float level 1/8 inch on mine when it does that.
Similar Threads
  1. 1979 40HP mercury Thunderbolt help
    By curtito in forum Mercury Mariner Outboard Archive
    Last Post: 08-04-2008, 03:54 PM
  2. More Speed on my yamaha 2002 40HP 4 cycle
    By roscopico in forum Yamaha Outboard Archive
    Last Post: 07-19-2008, 12:37 AM
  3. FuelOil mix and spark plug setting for 1982 40hp mariner 2 cycle
    By willy47 in forum Mercury Mariner Outboard Archive
    Last Post: 04-16-2008, 11:17 AM
  4. 03 Mercury 90 HP 2 cycle
    By Steve Baker in forum Mercury Mariner Outboard Archive
    Last Post: 05-08-2007, 11:32 PM
  5. 1979 Mercury 40hp
    By ken in forum Outboard motors archive 2000-2004
    Last Post: 08-18-2002, 09:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
