Hi, I have an 2003 Alpha 1 Gen 2 stern drive and am in the process of replacing the impeller. When I pulled the upper unit off about an ounce of Gear Oil came out along with the drive shaft. I was just wondering if this is normal or are there seals in the upper unit that need replacing. No water in the gear oil, either the oil that was drained from the unit or the ounce that came out with the shaft. Another thing that noticed is that there some wear on the shaft at or around the point where it sits in the seal. Again is this normal wear or something that I should be concerned about.
Thanks for your help
