Hello,
I have a Mercruiser 5.7L engine (8 cylinders) 2005, that overheated during activity, probably because the water holes were blocked (due to plants that grew up in the warm marine water).
The marine mechanic checked the compression in the cylinders, and saw that on one side (4 cylinders) there is water and on the other side there is low pressure (in one of them there was no pressure at all(
The mechanic said that it is probably cracked block, and the engine need to be taken out and examined.
Do you have any idea for something else I should check before replacing half of the engine?
Thanks in advance,
Ilia
Thanks in advance,
Ilia
