Where's the coolant going?
Walrus11
I am losing about a quart of coolant on my daily runs.
The oil is clean of coolant or water. There is nothing in the bilge.
Wouldn't the only logical answer would be that it's losing it through a tiny hole or crack in the heat exchanger?
Anyone have any ideas.
+1 or, you don't specify any info about your application but another possibility is if you have closed cooled manifolds, there may be a leak there.
Right! Good thinking. There's a plate and gasket between the manifold and riser elbow that COULD be leaking.
Jeff
