Results 1 to 3 of 3
  1. #1
    Default Eska 7HRSPWR, Model 1707
    Ok very new to the site and I am looking to see if someone can point me to the right direction. I just got a 7hrspwn eska, model 1707 from father in law. I can not read the recommendations for gas mixtures,and would also like to know basic info? I also think there is a problem with the shifter as when i move the neutral/forward handle, the mechanizm that should be moving to ship the motor into different gears doesnt move that much. Any help would be greatly appreciated. Thanks in advance. I cant wait to get this antique on the water.
  2. #2
    Join Date
    Aug 2010
    Bank of the Ohio river
    Default Re: Eska 7HRSPWR, Model 1707
    The shifter problem is most likely a rust problem "the nuetral clutch" and shift lever dog, turn it up side down and shoot PB Blaster at the drive shaft and soak it, see if you can squirt light oil in there, make sure if this is a twist grip that the grip is in the shift position or you will be locked out of shifting, if you don't never mind, if it is and has no markingsyou can feel your way to it withe the TG
    These people are Authorized resellers of Eska parts http://www.boatsportandtackle.com/servlet/StoreFront I have no affiliation other than having done business with them several times, good people to deal with. I strongly recommend that you buy a parts manual, Eskas are easy and you can extrapalate from the parts diagrams... I don't think I would wast money on a shop manual, but find the Tecumseh carb and engine manual floating around here or there you will need that. and its around....just ask
  3. #3
    Thanks for all the info MRCrabs, I really appreciate the help and all the info.
Similar Threads
  1. Eska Model #
    By ballbk in forum Eska Outboards
    Last Post: 07-22-2010, 06:42 PM
  2. Eska 5 Hp Model 14208A Broken TillerThrottle handle
    By sheepie99 in forum Eska Outboards
    Last Post: 03-14-2009, 11:02 PM
  3. Eska 3hp model 1973 B carb problems help
    By Bob Setzer in forum Eska Outboards
    Last Post: 10-29-2008, 10:31 PM
  4. Info on 95 hp ESKA model 1925B year unknown
    By mhuey in forum Archive 2003-2009
    Last Post: 04-24-2003, 07:01 PM
  5. Eska 5hp Outboard Model 1705C Serial 151378
    By martin in forum Outboard motors archive 2000-2004
    Last Post: 04-06-2001, 11:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
