Page 2 of 2 FirstFirst 12
Results 31 to 43 of 43
  1. #31
    Dec 2006
    Chaumont Bay, N.y., USA
    5,649
    Default Re: V6 to V8 engine swap
    Quote Originally Posted by pappymarty View Post
    I am trying to replace a 4.3L with a 360 ci V8. Is there an after market mount that will make up the additional length using existing mounting holes?
    Ayuh,... Welcome Aboard,... Ya mean a 350,..??
    I believe ya might have to swap the y-pipe to align things,....
    There's also various elbows, that go 'tween the risers, 'n y-pipe,....
  2. #32
    Thanks. 350 is correct. Hate those senior moments. I have the exhaust covered. The last thing is the front mounts. I could have something fabricated but thought there may be an after market extension that would use the existing holes.
    I am trying to stay away from drilling into the fiberglass. The structure for the motor mount stops short of the 350 mount.
  3. #33
    Mar 2009
    Portland, Oregon,
    10,407
    Marty, you will have better end results if you do not try to shortcut this.
    I'd suggest that you cut into your existing engine mount stringers, and extend them forward.
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
  4. #34
    Thanks Rick, I'm in uncharted water here.
  5. #35
    Mar 2009
    Portland, Oregon,
    10,407
    The waters are charted, perhaps just not by you.
    Post a few photos of your engine bay. One of us can help you.
    Also, maybe you will be able to find a YouTube video showing something similar being done.
    It is not all that difficult to do, and most people do better than what the factory did!
    Portland, Oregon
  6. #36
    Thanks but it will be Spring before I uncover this thing. More time and better weather. Problem has been, when I had time to work on the Sea Ray I had time to use the Bass Tracker.
    Thanks I'll get back to this.
    Marty
  7. #37
    I'm just finishing a 5.7 conversion into my '88 SeaRay Seville BR. It's been a ride! Yes you'll need to extend the motor mount bunks about 4.5". It wasn't hard, if you have any fiberglass experience (google will make you an expert! LOL)... I went to the local lumber store and picked up a scrap of 8x8 pretreated lumber... then cut it to fit my extension area... then supported with a slurry of fiberglass filler, then glassed over the block to match it to the original bunks... then Gel-coated... Looks totally OEM. I've been trying to do this on the cheap... but here's the details... EFI system from a 97 Mastercraft... Cam from the same motor... Rebuilt Jasper 5.7 Roller Vortec... V8 center riser exhaust manifolds (3" version - Uggh!)... These fit right onto my existing 4.3L "Y" pipe. I'm still hoping to find a 4" exhaust manifold set... One hassle so far has been rewiring the Mastercraft plug in (they use a 5x2 flat connector configuration)... However the biggest pain for me is the "high pressure" fuel pump, pre & post filters, and return line... I finally have a workable solution in my head, and expect to complete it by July 15 or so. I did pick-up a 1.50 ratio outdrive, and will put a new impeller and seals into it before installation.
    HERE"S MY QUESTION... Where should I start with proping my new 5.7L setup?
    With my 185-4.3L (1.84 outdrive ratio), I used a SS 14.25" x 18 prop... Max RPM was 5100 when trimmed perfect. I tried at least 8 different props before picking that as my best overall solution (near best out of the hole, best to 20mph, near best top end).
    Also, considering the extra weight and extra power... does anyone have a thought of what to expect in terms of increased performance?
  8. #38
    Dec 2006
    5,649
    Ayuh,.... Start with the prop ya got,....
    With the taller gear ratio, it might be dead on,.....
  9. #39
    Any thoughts about performance impact... will it be dramatic or ??? I really don't know what to expect. The boat is a deeper V design and is somewhat heavy already.
  10. #40
    Dec 2006
    5,649
    Ayuh,.... Goin' from a 4.3l to a 350 will be Noticeably more powerful,....
  11. #41
    "NOTICIBLY MORE POWER" will make it worth the effort! I did get it fired up on Saturday, it sounded wonderful! The fuel delivery system was a bit of an effort. Going from a single line mechanical fuel pump... to an electric high pressure EFI fuel pump, with High pressure fuel lines, clamps and fittings... plus a return line. To complicate matters, my donor boat (97 Mastercraft, was an inboard... and had all the fuel delivery at the motor's back end.) I learned alot! Do you think I'll need to insulate the fuel lines as they pass near the water pump and over the intake manifold? The lines are good for 300 degrees F., and 250 psi.
    Tonight I was building new seat platforms for the 2 jump seats that flank the engine cover. I had reconfigured the rear of the boat somewhat to gain better access. Before it was IMPOSSIBLE to get to the Plugs, wires, Oil drain plug and Oil filter because the engine compartment had side walls quite close to the exhaust manifolds. Those walls supported the rear jump seats, but ended up being a MAJOR PIA. Now they're gone... ) And access is far easier. And you can be calmed in that they were obviously not structual in nature.
    Do you have an opinion on the lower half of the outdrive as far as 1/R vs the MR? I have both, and both will fit onto the 1/R 1.50 upper. The MR lower is from the 4.3L install and I think I'll use that... unless someone would advise differently. I understnd the MR unit was redesigned with a bearing cup under the waterpump base plate. Thanks to all for the input.
  12. #42
    Mar 2009
    Portland, Oregon,
    10,407
    oops..... double entry
    Portland, Oregon
  13. #43
    Mar 2009
    Portland, Oregon,
    10,407
    Here is an updated image that better explains LPCP.
    Since LPCP is critical for performance, it becomes even more important to incorporate a Q/E into your SBC Marine build.
    Attachment 19263
Name:	LPCP explained.jpg
    Portland, Oregon
  1. Engine swap?
    By welshswampy in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-12-2011, 03:54 PM
  2. Engine swap in single engine Marinette
    By t_bennett in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 09-13-2009, 10:23 PM
  3. Engine Swap
    By harry_schlasinger in forum Test posting of messages, photos and formatting
    Last Post: 11-13-2008, 03:27 PM
  4. Swap Mercruiser engine to Volvo engine
    By jpflhr in forum Mercruiser Sterndrive Archive
    Last Post: 09-14-2006, 07:12 AM
  5. Engine Swap
    By northern_boy in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 05-04-2006, 07:55 AM
