yamaha tlrd 5o hp carb rebuild or fuel pump?
jpt
my engine will idle and go high on rpm with warm up but will not go up to plane and bogs down and stops on attempt to accell. to plane speed? primer bulb is ok and fuel ok which di i need fuel pump or carb repair? and does anyone have pics? of rebuild steps I have a kit
when the motor starts to stall pump the fuel bulb, if this makes the motor run right, its the fuel pump, when was the last time the carbs were cleaned? they are easy to do, just get a service manual and go step by step.
if your engine is starting normal idles fine rps are high and you are bogging... in low RPMs are you moving slowly? if that is the case it might be an easy fix. Your propeller hub most likely lost the grip on the seal... that is a $30-$50 fix at your local shop... let hope is that... good luck.
