Mike Kaldy
I just got a Bayliner 2655 Ciera a couple weeks ago and have been getting it ready to take out a couple times before winter. I tried warming it up to change the oil (with the water hose attachment on the outdrive) and it didn't pump any water into the engine. I pulled the lower unit off and checked it for a bad raw water impeller and it was fine. So I just continued with reassembling with new raw water pump gaskets and seals and changed the gear lube. So I tried it again today after being sure there were no line obstructions, and it still pumps no water up to the engine. I pulled the hose off and ran water into it, which lets water flow out the outdrive. No water is pumped out through the exhaust or up to the engine. I'm pretty lost as for what to try next, and I usually do all boat maintenance myself. Thanks for any help guys! Mike.
