I have a MR470 and the outdrive was shot, corroded lower leg but internals were perfect etc.
The MR outdrive was geared 1:84
I managed to pick up a good condition but second hand leg that was geared 1:65R and took the upper gear from the MR leg and swapped if over expecting the gearing to be the same as previously but the boat now seems to be under performing in comparison to previously.
I have check the obvious prop has not come free from the bush and that's fine.
I am taking the boat out of the water this weekend and wondered if anyone could tell me:
If I rotate the drive shaft one full revolution how many times should the prop turn?
I am guessing the it should turn .84 of a turn but I am only guessing.
Any help please would be appreciated ???
