FYI, not that you need this........, but the cover plays a role in the compression force against the thrust surfaces of the impeller.... ya know, the ends that ride against the deepest bore and against the cover!
Side step:
The later V/P V-8 crankshaft pump (the one that is integral with the serpentine style front shiv), uses an impeller that looks identical to the std 1027 impeller (that is common among the Johnson style crankshaft pumps).
Appartently there is .010/.020" differennce in the width of these two impellers..... otherwise, they look the same!
If the 1027 is installed in this pump, it bleeds back pressure to the suction side while at low RPM, and apparently can cause over-heating at low RPM.
Point being... yes, this is a very thin gasket, and we don't want to install a heavy gasket here that may change the thrust clearance dimension.
So always use the thin gasket here.
Long as we're on topic:
The
lower volume FB5-9 Johnson crank pump is similar to Jabsco's lower volume crank pump.
Johnson uses 4 cover screws.... Jabsco uses 6.
Each uses the same 1027 impeller (and an array of other p/n's for an equivilant impeller).
Both Johnson and Jabsco offer a
higher volume crank pump.
These pumps look the same as their lower volume...... but the impeller is wider... pump body is deeper!
Each uses a different impeller, but they look identical unless you were to measure them.
Johnson impeller is 1.900" wide.
Jabsco impeller is 1.990" wide.
Same diameter.... same blade count, etc. and it's tough to tell the difference by appearance only.
If you were to install the Johnson impeller in the Jabsco pump, you will have a problem.
It will breach suction!
(Jabsco impeller will not fit into the Johnson pump..... so no issues that way)
Parts guys often get this wrong by not asking the customer for a pump ID and/or model number.
The customer walks out the door with the wrong impeller.
So..... use caution!
