I was out fishing this past weekend and cruising down the lake at almost full throttle when I hit a barely submerged rock reef (apparently known as Prop Island). I manged to push the kill switch and shut off the engine after impact, after gathering my tthoughts as to what just happened I inspected the Prop for damage (Prop was a little dinged up but not too bad) and then started the engine again (it started on the 1st pull), everything seemed OK as I started to open up the throttle and the engine ran fine for about 30 seconds then it started to choke out and stall, I was able to restart the engine again but could only idle at slow speed (it runs perfectly fine at slow idle) as soon as I start to open it up it wants to choke out and stall. I managed to get back to the truck idling at minimum speed.
I'm hoping that someone might have had this problem and can help me out, I would appreciate any input regarding this problem.
Thank you kindly,
Steve
Thank you kindly,
Steve
