Results 1 to 3 of 3
  1. #1
    Default 6 hp evinrude 2 stroke Model E6RCUD
    I'm wondering if any of you can help with a diagnosis with my kicker engine. Today, while trolling in salt water, the engine suddenly changed the sound it was making (slightly, but enough to notice) and died. Would not restart after 3-4 pulls. <br>I noticed the cover felt hotter than normal and that steam was coming of the pee hole. Up to that point it was peeing water like normal. I tilted it up, rowed to shore and about 20 minutes later dropped it back down and restarted it. <br>All seemed okay, water peeing out, noise normal. I went back to trolling, but this time I kept checking the temp of the water coming out of the pee hole...it was not a steady temp, but kept bouncing between cool and hot, otherwise normal sound and operation. <br>After about 10 minutes running time, it died again, the cover was hot and steam came out of the pee hole again. Rowed to shore again...checked water intake...seemed clear...no other obvious issues when the cover was removed. <br>This motor is used infrequently, maybe only 5-10 times a year...the rest of the time it is stored upright in a barrel in a garage.<br>My preliminary diagnosis is either a blown head gasket or maybe a malfunctioning thermostat...what do you think? <br>Thanks.
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,890
    Default Re: 6 hp evinrude 2 stroke Model E6RCUD
    How old is the impeller ??---------They need to be replaced on a regular basis.---------------Head gasket ??-------Do a compression test !
  3. #3
    Join Date
    Jul 2007
    Location
    Barkhamsted, CT, USA
    Posts
    410
    I very recently had the exact same issue on my 6 HP 1989.
    It was the thermostat. It had literally come apart blocking water passages.
    Also as raceone says, if the impeller hasn't been replaced in a while, do it.
Similar Threads
  1. 2 stroke 15hp - Which model is my engine?
    By Jabricks in forum Yamaha Outboard Forum
    Last Post: 06-12-2011, 11:05 PM
  2. 1987 Evinrude model E6RCUD
    By justfishin in forum Johnson Evinrude Outboard Archive
    Last Post: 09-25-2008, 07:27 PM
  3. Yamaha 115 Four stroke 2003 model
    By Dennis Stout in forum Yamaha Outboard Archive
    Last Post: 07-08-2007, 07:37 PM
  4. Evinrude 2000 model 70 hp 4 stroke problems
    By hosnick in forum Johnson Evinrude Outboard Archive
    Last Post: 02-26-2006, 09:55 PM
  5. Late model evinrude 99 4 stroke carb adjustment
    By Bill kubiak in forum Johnson Evinrude Outboard Archive
    Last Post: 10-08-2003, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
