MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default 2003 Mercury 15 HP 4 Stroke Stahling Out
    Hello,
    I have a Mercury 15 HP 4 stroke that was brought down from Wisconson to Florida about a month ago. The engine ran fine in Wisconsin, but the two times that I have taken the boat out in salt water it stahls out after about 5 minutes in the water. The first time I took the boat out I didn't put fuel stablizer in the tank, but the second time I took the boat out I did. The boat seems to run fine with the choke on, but when I turn the choke off it stahls out.
    I recently had the brain of the engine replaced, because the engine shut-off button would not turn the engine off. I was hoping that this would fix the stahling problem, but it unfortunately did not. Thanks, Doug
  2. #2
    Join Date
    May 2007
    Location
    Ireland,the only country in the world you can go North to go South
    Posts
    1,876
    Default Re: 2003 Mercury 15 HP 4 Stroke Stahling Out
    Hi,
    Refer to user name as far as these motors are concerned but did you take the motor from a high elevation to sea level?Also the difference in humidity will affect the performance,never been to Florida but I hear it's got high humidity.
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,757
    Check the fuel line between the tank and the engine. If it is the White Mercury or Quick Silver line, chances are the liner inside the line has collapsed. Remove the line and take a look inside by cutting it open. Replace the line with the same type. Westmarine should have this line.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    Hello,
    I recently had the brain of the engine replaced, because the engine shut-off button would not turn the engine off. I was hoping that this would fix the stahling problem, but unfortunately it did not. Thanks, Doug
Similar Threads
  1. Mercury 2 stroke 125 HP 2003
    By Searayred in forum Mercury Mariner Outboard Forum
    Last Post: 03-10-2011, 11:10 PM
  2. Mercury 2003 9.9 Four Stroke, Fuel Pump
    By Bubba1 in forum Mercury Mariner Outboard Forum
    Last Post: 07-13-2010, 03:01 PM
  3. 225 hp 4 stroke 2003 mercury troubles
    By tmelton in forum Mercury Mariner Outboard Archive
    Last Post: 03-01-2007, 06:36 PM
  4. 2003 Mercury 50HP 4 stroke
    By Andy Phelps in forum Mercury Mariner Outboard Archive
    Last Post: 07-20-2006, 07:20 PM
  5. 2003 mercury 90 hp 4 stroke
    By binskiman in forum Mercury Mariner Outboard Archive
    Last Post: 05-04-2006, 10:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
