thanks paul for reply i have different issue now,itook engine to have lower end put by proffessional.no water coming out of telltale peehole,early before putting lower end on i knew this already.i replaced thermastat,impellor,waterpump top cover,before i put lower end on first time i hooked up garden hose to bottom of powerhead with adaptor,water came out of every oraphice like a firehose,telltale,exhaust,and water pump tube i replaced waterpump cover because i noticed hairline cracks from over tightening so i got new one put backtogether then had problem putting lower end in .i did twice before by myself no problem. this time i did not have magic, took it to shop they test ran it said no water at peehole itold about all passages being wide open .they said maybe crack in exhaust passage in head causing water to bypass and not going through engine. or idid not replace water pump correctly,is there any thing in bottom half of waterpump that i did not replace that can cause this
