Click forPleasurecraft Marine parts and manuals!
Results 1 to 5 of 5
  1. #1
    Default how to replace the boot on the stern drive on a sunliner pleasure craft marine 4cyl inboard outboard
    i need to know the procedure for removeing the sterndrive to replace the drive boot on 1987 pleasure craft sunliner 4 cyl inboard outboard any info would help
  2. #2
    Join Date
    Aug 2018
    Location
    Vermont
    Posts
    2
    Default Re: how to replace the boot on the stern drive on a sunliner pleasure craft marine 4cyl inboard outb
    Quote Originally Posted by scotthoward View Post
    I have a similar problem with a torn boot on an 86 Galaxy with a 4 cylinder Mercruiser. Just gotthe boat. Can I put this in the water with a torn boot?
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,378
    not unless you want to damage the internals of the drive....or sink the boat.....
    BTW, Mercruiser specific questions usually get fastest answers when posted in the Mercruiser forum...
  4. #4
    Join Date
    Aug 2018
    Location
    Vermont
    Posts
    2
    Quote Originally Posted by makomark View Post
    Mercruiser forum here I come. But...I am reading that the boot I had in mind is the exhaust bellows, which is more for directing exhaust into the water to muffle sound and isn’t water tight anyway. That said, might be wise to do a full bellows set replacement since the other bellows—if they leak—can indeed result in a trip to the bottom.
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,378
    The exhaust boot isn't an issue, the larger one, above it, that protects the U-joints, is the one for concern....if the boat was stored with the drive up, a replacement would be in order.....store the boat with the drive down....also, any cracks (from age) warrant a replacement....
Similar Threads
  1. Honda outboard to replace Volvo pent mb2/50s inboard sail drive
    By René Côté in forum Honda Outboard Forum
    Last Post: 07-11-2011, 10:50 PM
  2. Raw Water Pump for 87' Pleasure Craft 350
    By mysticalcracker in forum Pleasurecraft Marine PCM Forum
    Last Post: 07-08-2011, 10:37 AM
  3. 1983 Pleasure Craft 351 with Ignitor system will not start
    By 82skisupreme in forum Pleasurecraft Marine PCM Forum
    Last Post: 08-29-2010, 07:50 PM
  4. Stern drive engine to inboard
    By sammi in forum Crusader Marine Engine Forum
    Last Post: 01-07-2010, 12:13 PM
  5. 351 pleasure craft
    By paul3 in forum Pleasurecraft Marine PCM Forum
    Last Post: 05-27-2009, 01:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
