MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default 89 Mariner 2 stroke 15hp carb spitting gas
    Upon priming and trying to start, fuel spits out of a notch cut into the top right side of the carb. It is enough to drip a large amount down through the engine body and I am scared to run it with this. It looks like the notch was machined in the carb, it has a gasket on it held by 2 screws. What could be causing this and how can I fix it? Please help!
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,395
    Default Re: 89 Mariner 2 stroke 15hp carb spitting gas
  3. #3
    Yes. That notch you see in 15/16 is where it is coming out of. Is this some kind of a bypass/overflow? The motor will not start and there is so much fuel it may not be getting to the combustion chamber.
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,395
    Don't know. Looks like you need #15 the gasket/diaphragm kit. The diaphragm is probably torn after 22 years. That parts diagram was selected at random so select your engine by serial number for the correct parts from below.
    http://www.mercruiserparts.com/selec...asp?doc_nbr=15
Similar Threads
  1. Carb Spitting Gas 1990 70hp
    By gizmoe107 in forum Chrysler Force Outboard Forum
    Last Post: 03-28-2010, 09:54 PM
  2. Differences in 99hp and 15hp 2 Stroke Mariner outboards
    By backhoe_bob in forum Test posting of messages, photos and formatting
    Last Post: 04-18-2009, 12:01 AM
  3. 99hp Mariner 2 stroke 2001 Conversion to a 15hp
    By backhoe_bob in forum Mercury Mariner Outboard Archive
    Last Post: 04-17-2009, 03:45 AM
  4. Carb spitting fuel
    By jamiel in forum Johnson Evinrude Outboard Archive
    Last Post: 09-01-2008, 04:09 PM
  5. Fuel spitting carb
    By roz58 in forum Chrysler Force Outboard Archive
    Last Post: 07-18-2007, 06:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
