MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default 1977 mercury 4hp 2 stroke starts but cuts out
    hi i need help my engine will start for 3 seconds then stops, can any one help do i need to alter carb? spark plugs ok fuel is clean... please help
  2. #2
    Default Re: 1977 mercury 4hp 2 stroke starts but cuts out
    hi there i have same problem (above thread) all my fuel is clean i cleaned the carb and evan has fuel (small amount) coming out of carb air intake mine will only start at wide open throttle and then die after 2-3seconds.. I know this isnt much help but your not the only one..
    regards tom
  3. #3
    Join Date
    May 2007
    Location
    Ireland,the only country in the world you can go North to go South
    Posts
    1,855
    There is a difference between both outboards, Tom's carb, http://www.crowleymarine.com/mercury...arts/456_5.cfm , going by the pic Tom posted, http://www.crowleymarine.com/mercury...arts/472_6.cfm , robmcc85's carb .
    Clean the carb,blow out all the passage ways,seat the idle screw,back it out 1 1/2 turns,then keep backing it out 'til you get it to idle,then do as guyjg says on Tom's post
    If buying parts,try and get them here on http://www.marineengine.com/ as it helps keep the forum up and running.
  4. #4
    thanks tom ,haventaclue, will try and clean carb out and keep you informed
Similar Threads
  1. Replies: 1
    Last Post: 07-18-2011, 09:55 PM
  2. 1999 Mercury 15 hp 4- stroke cuts out when warm
    By river22 in forum Mercury Mariner Outboard Forum
    Last Post: 03-25-2011, 03:16 AM
  3. Aq131a starts and runs well but cuts out when warm
    By markymark in forum Volvo Penta Gas Archive
    Last Post: 07-11-2009, 10:14 PM
  4. PCM 351 Starts and then cuts out
    By Christian Theumer in forum Pleasurecraft Marine PCM Forum
    Last Post: 07-05-2008, 01:40 PM
  5. 5 hp starts and then cuts out quick
    By Benedita Sylvia in forum Suzuki Outboard Archive
    Last Post: 05-29-2007, 02:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
